Normal Topic Nodes are appearing blank with new version 2.4 (Read 1498 times)
Anshul
Senior Member
Sep 14th, 2010 at 6:10am
With Mindfusion.Diagramming.Wpf version 2.4, we are getting blank nodes for some specific format of text. If we set some text in Node's text property, node is not displaying the text at UI although during debugging we are able to verify that Text property is getting set.
Let’s try "Test (00) of IRD - 1fhjj" as Text for the Node.
I am sending a sample too for this issue. Please let know the solution as soon as possible.
Anshul
Re: Nodes are appearing blank with new version 2.4
Reply #1 - Sep 14th, 2010 at 7:55am
Set labelNode.TextPadding = new Thickness(0); Otherwise now there is one millimeter default padding at each side of the node, and the text cannot fit in the 15-point high label node.
Anshul
Senior Member
Reply #2 - Sep 14th, 2010 at 8:01am
Thanks Stoyan Smiley
