Normal Topic Selection improvement (Read 1357 times)
luffy911
Sep 28th, 2010 at 7:12pm
Hello Stoyan,
Was there an easy way to override the selection behaviour in Flow Chart ? My main concert is the rectangle selection. I would like to add features like if you hold ctrl, you will add to the current selection and if you hold alt you will remove from the current selection.
luffy
Re: Selection improvement
Reply #1 - Sep 29th, 2010 at 10:50am
Hi Luffy,
I can't find anything specific provided for this requirement. What you could do is save a Selection.Items copy from the SelectionChanged handler and upon the next SelectionChanged add or remove the previous items, depending on Keyboard.Modifiers.
luffy911
Reply #2 - Sep 29th, 2010 at 2:59pm
It works really well !
Thank you
Luffy
