Normal Topic Inheritance from DiagramLink (Read 2187 times)
Hunter
Oct 5th, 2010 at 6:20am
Hello, Stoyo!
I need to do the following. I need show the tooltip when mouse is over the diagram link. To do this I plan to inherit the class from DiagramLink and add 2 properties: Desription and HyperLink on the image which will shown when tooltip opens. So I create the class:
    public class TPDEDiagramLink: DiagramLink
        #region Properties
        /// <summary>
        /// Gets or sets the description.
        /// </summary>
        /// <value>The description.</value>
        public String Description
            get { return m_sDescription; }
            set { m_sDescription = value; }
        /// <summary>
        /// Gets or sets the image hyperlink.
        /// </summary>
        /// <value>The image hyperlink.</value>
        public String ImageHLink
            get { return m_sImgHLink; }
            set { m_sImgHLink = value; }
        /// <summary>
        /// Gets or sets the index of the image.
        /// </summary>
        /// <value>The index of the image.</value>
        public int ImageIndex
            get { return m_nImgIdxInDb; }
            set { m_nImgIdxInDb = value; }
        #endregion //Properties
And I need to serialize this properties and save them into database. I need to override functions SaveToXml(), LoadFromXml() and Clone() for make possible to copy this objects and paste them into the diagram. And the question is following: what type of DiagramLink constructor I need use in the Clone() method?
Thanks.
Hunter
Re: Inheritance from DiagramLink
Reply #1 - Oct 5th, 2010 at 7:01am
Oh! Sorry, I understood! Is it correct:
	  /// <summary>
	  /// Clones the specified clipboard.
	  /// </summary>
	  /// <param name="clipboard">if set to <c>true</c> clipboard.</param>
	  /// <returns></returns>
	  public override DiagramItem Clone(bool clipboard)
		TPDEDiagramLink link = base.Clone(clipboard) as TPDEDiagramLink;
		link.Description = Description;
		link.ImageHLink = ImageHLink;
		link.ImageIndex = ImageIndex;
		return link;
Hunter
Reply #2 - Oct 5th, 2010 at 11:17am
I set in the constructor of my user control the following:
void InitLinks()
		m_Diagram.LinkCascadeOrientation = MindFusion.Diagramming.Wpf.Orientation.Auto;
		m_Diagram.LinkSegments = 15;
		m_Diagram.Behavior = Behavior.Custom;
		m_Diagram.CustomLinkType = typeof(TPDEDiagramLink);
		m_Diagram.CustomBehavior = new LinkBehavior(m_Diagram);
		m_Diagram.LinkHeadShape = ArrowHeads.Triangle;
		m_Diagram.LinkHeadShapeSize = 10;
		m_Diagram.LinkBrush = Brushes.Black;
		m_Diagram.LinkShape = LinkShape.Cascading;
		m_Diagram.LinksSnapToBorders = false;
		m_Diagram.SnapToAnchor = SnapToAnchor.OnCreateOrModify;
But when I draw link in is created as DiagramLink but not as TPDEDiagramLink. What's wrong?
Reply #3 - Oct 5th, 2010 at 11:22am
If you assign an instance of your own behavior class to CustomBehavior, it should override the CreateLink method to return a TPDEDiagramLink.
Hunter
Reply #4 - Oct 5th, 2010 at 11:53am
Yes, it helps. Thanks.
