Normal Topic ListBox from xml exported file (Read 2174 times)
svendazjer
Oct 8th, 2010 at 4:31pm
Hi, I'm tryng to load an xml file exported from the flowcharterto the listbox, but when I loaded into the listbox list the right number of items but not the right properties of them, such as shape or text values...
if anyone can help I would really appreciate.
thanks in advance.
Re: ListBox from xml exported file
Reply #1 - Oct 8th, 2010 at 6:25pm
How exactly are you loading a diagram file into a listbox?
svendazjer
Reply #2 - Oct 8th, 2010 at 6:57pm
I'm tryng opening the file with the LoadFromXml function, like this diagram.LoadFromXml(_openFileDialog.FileName);
then I try to to get the nodes from the diagram,
DiagramNodeCollection mynodecollection = diagram.Nodes;
and then I use  a foreach structor to proccess each node and put it into the listbox, like this
foreach (DiagramNode mynode in mynodecollection)
       _nodeList.Items.Add(mynode);
But didn't work.
I also try to open the file as an XmlDocument, and put each node into thge listbox as and XmlNode, somthing like:
XmlDocument myxmldocument=new XmlDocument();
myxmldocument.Load("Sample.xml");
XmlNode mynodes=(XmlNode)myxmldocument.DocumentElement;
foreach (XmlNode mynode in mynodes["Nodes"])
But didn't work.
This is the Xml file that I'm using: http://tinyurl.com/2exb9sh
Also I'm using C# and Visual Studio 2008
Reply #3 - Oct 8th, 2010 at 8:15pm
Is _nodeList a ListBox or ShapeListBox? If you need to display node shapes inside a ListBox, check how they are custom-drawn in the Flowcharter sample project. If it's a ShapeListBox, you can add Shape objects to it (e.g.  mynode.Shape).
