Normal Topic Unable to move link head/tail (Read 3092 times)
madhukampurath
Oct 15th, 2010 at 12:38pm
I am using ImageMap for ClientSideMode. I cannot allow hanging links on diagrams and so I set both AllowUnAnchoredLinks and AllowUnconnectedLinks as false.
But then, I am not able to move the link heads or tails. The move cursor (+) comes when I place the mouse over link head. However, it is not moving. Sometimes, the diagram creator will need to do move the link heads so that the diagram looks good. May I know how I can acheive both these requirements together?
Madhu
Re: Unable to move link head/tail
Reply #1 - Oct 15th, 2010 at 2:48pm
Could you check if you haven't also disabled the LinkEndsMovable / AllowMoveEnd properties by some chance.
madhukampurath
Reply #2 - Oct 18th, 2010 at 8:25am
I am setting LinkEndsMoveable as true. But, this does not solve the problem. Is there anything else, I should do?
Madhu
Reply #3 - Oct 18th, 2010 at 11:20am
Have you set the AnchorPattern property of all nodes? If it's null for some node and AllowUnanchoredLinks == false, you won't be able to attach a link to the node. Disabling AllowUnconnectedLinks should be enough to prevent hanging links, so if you are not using anchor-patterns, set AllowUnanchoredLinks = true.
madhukampurath
Reply #4 - Oct 19th, 2010 at 4:21am
Hi Stoyo,
Setting AllowUnanchoredLinks = true solved the issue.
Many thanks.
Madhu
