Normal Topic need a OnDropOver Functionality. (Read 2091 times)
yrauma
Oct 25th, 2010 at 5:25pm
Hello Stoyan.
Im fighting with the documentation but cannot find anything about it.
I need to know if the user remove multiple node from a container at once.
I can spy when the user add multiple elements with Container.OnDropOver which is called with a selection.
But in the other way (removing multiple elements) its doesnt sound possible.
How can I do that ? or else is there any way to know begining and start of the operation and not just receive delete events one by one ?
Re: need a OnDropOver Functionality.
Reply #1 - Oct 25th, 2010 at 5:58pm
Hi Amaury,
At this time you can do that by handling both ContainerChildRemoved and SelectionMoved. The ContainerChildRemoved  handler could collect the removed items in some List<Node>, and then process the list from SelectionMoved and clear it.
yrauma
Reply #2 - Oct 25th, 2010 at 9:31pm
Once again Stoyan you helped me a lot Cheesy
(and you remembered my name, makes me think I have a lot of problems ahahah)
Its not that nice , but still, working totally fine.
Thanks a lot Stoyan.
