Normal Topic zoom and others (Read 7678 times)
granit
zoom and others
Nov 26th, 2010 at 5:33pm
Dear Stoyo, several questions
1) Layout/Fit/Undo note
Step1. Spring layout operation of test diagram
SpringLayout layout = new SpringLayout();
layout.Arrange(this.diagram1);
Step2. Fit its bounds.
this.diagram1.ResizeToFitItems(1);
Step3. [Undo] operation
this.diagram1.UndoManager.Undo();
initial layout restored, fit operation not stored in command history stack.
How to remember fit operation in command history stack?
2) I found that it is possible to set diagramView zoom bounds (ZoomToRect function) but not found a way to get current «zoom rectangle». If such function exists, please point me to it. If not, is it possible to include something similar in the future?
3) See picture below. With big pen width and arrowhead diagramLink rendered as lower picture. Is it possible to render link with head as upper picture?
4) See picture below. After diagram saving to binary with wmf pictures in nodes (diagram.savetofile) and reopening it (diagram.loadfromfile) wmf pictures in shape nodes renders like bmp.
5) picture below. ZoomFactor zooms picture relatively upper left point of zoom area (black lines on picture). Is it possible for zooming relatively center of zoom area (red lines)?
6) picture below. Is it possible to get building functionality for zooming similar multiple selection? I mean selecting zooming area by mouse, with following zooming diagram to this rectangle (see Zoom Tool (magnifier) in Adobe Photoshop, for example). I think itis very handy function.
Best
Vlad
Re: zoom and others
Reply #1 - Nov 26th, 2010 at 9:43pm
6) Try assigning an instance of this class to DiagramView.CustomBehavior:
class ZoomTool : BehaviorBase
	public ZoomTool(DiagramView diagramView) : base(diagramView)
		Diagram.NodeSelecting += Diagram_NodeSelecting;
		Diagram.LinkSelecting += Diagram_LinkSelecting;
	void Diagram_LinkSelecting(object sender, LinkValidationEventArgs e)
		e.Cancel = zoomInteraction != null;
	void Diagram_NodeSelecting(object sender, NodeValidationEventArgs e)
	protected override void OnMouseUp(Point mousePosition, System.Windows.Forms.MouseButtons mouseButton)
		if (zoomInteraction != null)
			DiagramView.ZoomToRect(zoomInteraction.CurrentItem.GetBounds());
base.OnMouseUp(mousePosition, mouseButton);
		zoomInteraction = null;
	public override InteractionState StartDraw(PointF point)
		zoomInteraction = new InteractionState(Diagram.Selection, -1, Action.Create);
		return zoomInteraction;
	public override CursorHint SetMouseCursor(PointF point, out bool startInteraction)
		startInteraction = true;
		return CursorHint.Pointer;
	private InteractionState zoomInteraction;
granit
Re: zoom and others
Reply #2 - Nov 29th, 2010 at 6:37am
Stoyan, thanks for answer.
Concerning image restoration after saving/loading diagram (question 4 in first post) I found the same behaviour in case of copy/past operations through diagramView.CopyToClipBoard/diagramView.PasteFromClipboard tools
Best
Vlad
Re: zoom and others
Reply #3 - Nov 29th, 2010 at 7:53am
5. Try the following method:
private void ZoomInCentered()
	RectangleF viewRect = diagramView.ClientToDoc(diagramView.ClientRectangle);
	viewRect.Inflate(- viewRect.Width * 0.1f, - viewRect.Height * 0.1f);
	diagramView.ZoomToRect(viewRect);
Re: zoom and others
Reply #4 - Nov 29th, 2010 at 8:10am
4. happens because the control calls Image.SaveToStream when saving images, but the framework does not provide a metafile encoder and falls back to PngEndoder. You can verify that like this:
new Metafile("test1.emf").Save("test2.emf");
Now if you open test2 with the VS binary editor, it will have the PNG header. As a work-around you could override the SaveTo and LoadFrom methods of nodes to save the file path to the WMF images, and then load the original images from LoadFrom.
Re: zoom and others
Reply #5 - Nov 29th, 2010 at 10:03am
For 3 you could try some custom drawing. E.g. check this sample, though it won't work with some arrowhead shapes:
https://mindfusion.eu/_samples/ArrowPenTest.zip
Re: zoom and others
Reply #6 - Nov 29th, 2010 at 12:59pm
1) As you've noticed resizing the diagram is not subject to undo/redo. To enable undo/redo, you can use the following custom command:
class ResizeToFitCommand : Command
	public ResizeToFitCommand(Diagram diagram)
		: base("Resize")
		this.diagram = diagram;
	protected override void Execute(bool undoEnabled)
		bounds = diagram.Bounds;
		diagram.ResizeToFitItems(1);
	protected override void Undo()
		diagram.Bounds = bounds;
	protected override void Redo()
		Execute(true);
	private Diagram diagram;
	private RectangleF bounds;
Then, modify your code as follows:
CompositeCmd composite = diagram1.UndoManager.StartComposite("Arrange and resize");
SpringLayout l = new SpringLayout();
l.Arrange(diagram1);
diagram1.ExecuteCommand(new ResizeToFitCommand(diagram1));
composite.Execute();
2) To get the current viewport expressed in document coordinates, use the following code:
RectangleF viewport = diagramView1.ClientToDoc(diagramView1.ClientRectangle);
I am assuming that diagramView1 is the DiagramView containing the respective diagram.
Let me know if this helps.
granit
Re: zoom and others
Reply #7 - Dec 1st, 2010 at 2:16pm
thanks
best
vlad
