Normal Topic CellTime vs SnapUnit (Read 3049 times)
Gerco
Dec 2nd, 2010 at 9:22am
Is it possible that my appointments snaps on snapunit instead of snapping on the cellpresenters.
For example:
My CellTime is 15 minutes, but i would like my appointment to snap every 5 minutes.
calendar.TimetableSettings.EnableSnapping = true;
calendar.TimetableSettings.SnapUnit = MindFusion.Scheduling.Wpf.TimeUnit.Minute;
calendar.TimetableSettings.SnapUnitCount = 5;
calendar.TimetableSettings.CellSize = 10;
calendar.TimetableSettings.CellTime = new TimeSpan(0, 15, 0);
When my appointment is from 7:00 to 8:05, it seems like it's from 7:00 to 8:15.
I could also set my celltime on "new TimeSpan(0, 5, 0)" but then it takes much longer to load the calendar ( calendar.EndInit() )
Re: CellTime vs SnapUnit
Reply #1 - Dec 2nd, 2010 at 11:45am
By default the items visually expand to cover the entire cells. To turn this feature off, set TimetableSettings.ShowPadding to false.
Let me know if this helps.
Gerco
Reply #2 - Dec 2nd, 2010 at 1:32pm
Yes it works!
Thanks you!
Gerco
