Normal Topic Background property (Read 2374 times)
PDM.
Senior Member
Background property
Dec 7th, 2010 at 3:12pm
<d:Diagram Name="form" BackBrush="Transparent" BackgroundImage="/imagetest.png"
SelectAfterCreate="False"
NodeCreated="form_NodeCreated"
NodeActivated="form_NodeActivated"
InitializeNode="form_InitializeNode"
NodeSelecting="form_NodeSelecting"
</d:Diagram>
Backgroundimage just not work and return exception
BackgroundBrush, just nto work and i cant setup to transparent and or colors.
Some help?
Hope can amke work thsi 2 things, if not this component is useles to me ; (
Im working over example provided called FORMEDITOR
« Last Edit: Dec 8th, 2010 at 5:05pm by PDM. »
Re: Background property not work !!
Reply #1 - Dec 7th, 2010 at 3:56pm
You don't have to set BackBrush to transparent, the image is always rendered after the background is filled. BackgroundImage works fine in our test, both as an external file in the .exe's folder and as an embedded resource. Try adding this file to the project and setting its Build Action to Resource in the property pane.
PDM.
Senior Member
Reply #2 - Dec 7th, 2010 at 5:03pm
About background image i fixed the problem is my error , fixed now.
ABout transparent backgroud i need that too, due my appz is very special, i find the way to fix that : )
Stoyo you are the owner and creator of mindfusion? or only part of support team?
(just for curiosity)
« Last Edit: Dec 8th, 2010 at 12:50am by PDM. »
Reply #3 - Dec 8th, 2010 at 9:22am
Support only but perhaps associate soon 8) If you need to make the whole window transparent, check these links -
http://stackoverflow.com/questions/765365/create-a-transparent-hole-inside-a-win...
http://blogs.interknowlogy.com/johnbowen/archive/2007/06/20/20458.aspx
You might have to apply transparency to the other controls in the UI tree, such as the ScrollViewer.
