Page Index Toggle Pages: 1 2 [3]  Send TopicPrint
Very Hot Topic (More than 25 Replies) form.Nodes.Count issue (Read 22342 times)
Re: form.Nodes.Count issue
Reply #30 - Feb 11th, 2011 at 11:19am
Have you perhaps added it to the GAC recently? I think GAC assemblies are not copied to the output folder by default.
Reply #31 - Feb 11th, 2011 at 11:25am
... though the runtime should be able to load it from the GAC in that case.
PDM.
Senior Member
Reply #32 - Feb 11th, 2011 at 12:54pm
Absolutly thankyou !!
Finally fixed!
PDM.
Senior Member
Reply #33 - Feb 21st, 2011 at 2:21pm
Copy paste 2.5.1 not work at all.
Is very strange, when i copy and paste, the object not are copied with original colors and propertys, but if i save  and open, node object is showed correctly.
Can take a look on this?
Want i upload an exaple for better reference to the toruble?
Probably is soemthing im doing wrong.
Best regards.
Reply #34 - Feb 21st, 2011 at 9:04pm
You are handling CopyHostedControl to avoid losing the Xaml binding expressions, right? Now you'll have to copy yourself the color properties from the event handler; the standard copy/paste code through XamlWriter/XamlReader does not run when you handle that event.
PDM.
Senior Member
Reply #35 - Feb 21st, 2011 at 9:40pm
Yes im hanlding CopyHostedControl, for that reaosn think is a bug.
Can take a look, or want i upload example?
PDM.
Senior Member
Reply #36 - Feb 22nd, 2011 at 7:47am
void form_CopyHostedControl(object sender, CopyHostedControlEventArgs e)
if (e.Source is MyButton)
var destNode = Diagram.GetDiagramItem(e.Destination) as DiagramNodeAdapter;
var button = new MyButton();
button.Text = ((MyButton)e.Source).Text;
button.Stroke = ((MyButton)e.Source).Stroke;
destNode.Control = button;
And not work object is copied, but stroke showed in blank, no text showed.
When i save and load again object show correct text and color in stroke
What im doing wrong?
Reply #37 - Feb 22nd, 2011 at 9:27am
It looks ok, are you sure you are not resetting the values later? for example in the NodePasted event handler.
PDM.
Senior Member
Reply #38 - Feb 22nd, 2011 at 9:51am
Hi again, i removed all code from NodePasted, and see the problem continue.
One question
Event is fired automatically when node is pasted? or have to add some line of code for fire the event?
In that case what is?
Probably is that what i forgot : )
Reply #39 - Feb 22nd, 2011 at 10:59am
You must set form_CopyHostedControl as a handler of the CopyHostedControl event, add this to the Diagram element in the Xaml file:
CopyHostedControl="form_CopyHostedControl"
PDM.
Senior Member
Reply #40 - Feb 22nd, 2011 at 11:23am
Thankyou!
Finally work!   Tongue
