Normal Topic Want consistent font size irrespective of zoom (Read 4712 times)
Anshul
Senior Member
Jan 5th, 2011 at 7:44am
If diagram's zoom factor is >=100, we want that node's text should not get increase with the diagram zoom factor i.e. node should be zoomed but not its text.
Also, if node's text is trimmed at 100 zoom factor than we want if we increase the zoom factor, text size should appear the same and it should display some more text which was previously trimmed.
Let know how can we achieve this?
We are sending a sample in which we are performing zoom by mouse wheel but text font is increasing with the diagram zoom factor and also, at higher zoom factor we are not able to see trimmed text.
Anshul
Re: Want consistent font size irrespective of zoom
Reply #1 - Jan 5th, 2011 at 11:07am
This should do the trick:
private void diagram_ZoomFactorChanged(object sender, EventArgs e)
	foreach (DiagramItem item in diagram.Items)
		item.FontSize *= lastZoom / diagram.ZoomFactor;
	lastZoom = diagram.ZoomFactor;
private double lastZoom = 100;
Bala
Reply #2 - Jan 7th, 2011 at 10:45am
Hi Stoyan,
Thanks for the reply.
It has resolved our issue except a small one.
We have set TextAllignment to Right. When text is larger enough that it is coming in two line than text is right alligned for both the line, we want text alligment as right for first line line only and for second line text should be left alligned.
Please let know your suggestion.
Bala
Reply #3 - Jan 7th, 2011 at 1:52pm
Indeed TextAlignment affects all lines. If you need one line to be right-aligned and the second line left-aligned, you won't be able to use the built-in text rendering but will have to custom-draw the text.
Bala
Reply #4 - Jan 7th, 2011 at 2:19pm
How we can do that in our custom shaped node?
Reply #5 - Jan 8th, 2011 at 8:59am
Here you can find a simple text renderer that outputs the first line right-aligned and the rest of them left-aligned:
http://mindfusion.eu/_samples/Draw2AlignedText.cs
You can use the Draw2AlignedText method like this to show the text on the left of a node:
private void diagram_DrawNode(object sender, DrawNodeEventArgs e)
	var node = e.Node;
	var localRect = new Rect(-150, 0, 150, e.Node.Bounds.Height);
	Draw2AlignedText(e.Graphics, node.Text, localRect, node);
Bala
Reply #6 - Jan 10th, 2011 at 7:04am
Hi Stoyan,
I am calling node.Repaint(false); from ZoomFactorChange event handler but Diagram_DrawNode() is not getting called. Can you please let know how to fire DrawNode event explicitly?
Bala
Reply #7 - Jan 10th, 2011 at 7:12am
Have you set the node.CustomDraw property?
Bala
Reply #8 - Jan 10th, 2011 at 8:47am
No, I have not set node.CustomDraw property.
Reply #9 - Jan 10th, 2011 at 11:00am
DrawNode is raised only if CustomDraw is different from None. For example set it to Additional to get the standard drawing of ShapeNodes done before raising the event. In that case also set TextBrush = Transparent to stop the default text rendering.
