Normal Topic Set vertical position (Read 3060 times)
Gerco
Jan 13th, 2011 at 8:11am
I have a scheduler with the timetableview. My scheduler shows the complete day (0:00 - 23:59).
When the scheduler loads, the appointments get loaded. And most of the time the appointments are between 8am and 5pm.
I would like my schedule to focus on 8am, so that if the appointments are loaded, the scheduler vertical scrollposition needs to change.
Basically, I need my scheduler to scroll to 8pm on startup.
Is this possible? I already tried to set calendar.VScrollPos, but that didn't do the trick.
Re: Set vertical position
Reply #1 - Jan 13th, 2011 at 9:19am
Can you try setting this property after the control has been loaded? It currently seems to ignore any sets before that.
Let me know if this workaround works.
Gerco
Reply #2 - Jan 13th, 2011 at 11:52am
Yes, it works! Thanks!
