Normal Topic ZoomFactor binding is not working (Read 2613 times)
rajesh_patil74
Jan 27th, 2011 at 1:10pm
Hi Stoyo
I seen that zoomfactor is dependency property. But I am not able to do binding for same in xaml file.
At run time , i get exception
"ZoomFactor must be positive number" ... even my model file property (which is used for binding) has value set to 100.
-Rajesh
Re: ZoomFactor binding is not working
Reply #1 - Jan 27th, 2011 at 3:15pm
Hi Rajesh,
The throw code looks like this, so the exception will only happen if your bound value is 0 or a negative number at some point -
if ((double)e.NewValue <= 0)
     throw new ArgumentException("ZoomFactor must be positive number");
rajesh_patil74
Reply #2 - Jan 28th, 2011 at 4:55am
Hi Stoyo
What I observed is that, when xaml file gets loaded the datacontext for the xaml page is not assinged and at that time exception gets raised since the value assinged in xmal exceutes the assingment statment and at that time value of zoomfactor is passed as 0.
-Rajesh
Reply #3 - Jan 28th, 2011 at 8:56am
Can't you set DataContext before the InitializeComponent call in the Page constructor?
