Normal Topic 32-bit application on 64-bit machine (Read 2512 times)
MagnusSpeychal
Feb 15th, 2011 at 2:36pm
Hi
I have compiled my application as a 32-bit application and I want to run it as a 32-bit application on a 64-bit machine. When I try this the application crashes when using the FlowChartX control. I am using FlowChartX professional edition 4.1.5.
Do I need to do something special to make this work or doesn't this work with the version 4.1.5 dll:s?
Magnus
Re: 32-bit application on 64-bit machine
Reply #1 - Feb 16th, 2011 at 6:54am
You only have to register the flowchart.dll as COM control. Doesn't the flowchartx demo run on that system? It is a 32-bit app and runs fine on our 64-bit development systems.
MagnusSpeychal
Reply #2 - Feb 18th, 2011 at 7:28am
Hi Stoyan
The demo and application work fine on another 64-bit machine. The problem must be related to something else.
Thanks for your help!
/ Magnus
