Normal Topic which files redistribute vs2008 prj flowchart ? (Read 4916 times)
strong_peng
Jan 19th, 2011 at 4:00am
i build project with vs2008,
i run it  fine in my machine.
when i run in other machine failed.
flowchart version is 4, 1, 4, 0
i just regedit flowchartpro.dll
when i install flowchar install cab in other machine .
the project run fine.
which files i need when i redistribute project builed by vs2008?
Re: which files redistribute vs2008 prj flowchart
Reply #1 - Jan 19th, 2011 at 6:55am
What do you mean by "just regedit flowchartpro.dll"? Have you registered the flowchart.dll as a COM control on the other machine? E.g. mark it as COM self-registering library in your installer, or register it using the regsvr32 tool.
strong_peng
Reply #2 - Jan 20th, 2011 at 6:19am
yes, i run command regsvr32 flowchartpro.dll  ,one program builed with vs2003 is good on same machine.
Reply #3 - Jan 20th, 2011 at 7:24am
Is your new project loading flowchart objects dynamically, for example via VB control arrays or by calling CWnd::CreateControl?
strong_peng
Reply #4 - Jan 20th, 2011 at 7:41am
yes
m_chatTopo.Create("FlowChart",WS_CHILD|WS_VISIBLE|WS_BORDER,CRect(0,100,0,100),t
his,IDC_TOPOVIEWCHART);
Reply #5 - Jan 20th, 2011 at 8:01am
You must use the Create overload that takes a string parameter specifying a runtime license key. Contact support@mindfusion.eu to get one if you don't have it. Otherwise the IDE takes care of this automatically when the control is loaded from a form / dialog resource.
strong_peng
Reply #6 - Jan 20th, 2011 at 8:33am
how create overload ?
"m_chatTopo.Create("FlowChart",WS_CHILD|WS_VISIBLE|WS_BORDER,CRect(0,100, 0,100),this,IDC_TOPOVIEWCHART); "
need change code ?
where runtime license key in install cab ?
Reply #7 - Jan 20th, 2011 at 9:37am
Are you using MFC ot ATL?
