Normal Topic Two questions... (Read 1900 times)
phd_sweden
Two questions...
Jan 2nd, 2011 at 10:04pm
Two questions...
Q1) How to control the number of arrow that can be draw to an anchorpoint?
Q2) How to make it impossible to draw an arrow from an input  anchorpoint to a output anchorpoint (or vs.) which belong to a single box?
Re: Two questions...
Reply #1 - Jan 3rd, 2011 at 1:49pm
1. If you are not using undo/redo, an easy solution is to delete the new arrow in response to the ArrowCreated event. In that case you will know to which anchor point the arrow has been attached, and can count how many arrows are attached to it. Otherwise you can prevent that from the validation event RequestCreateArrow, but you will need some additional code to detect the nearest anchor point because it is not passed as argument to the event. I can send you some sample code if you need detecting the nearest point.
2. Set AllowRefLinks = false.
