Normal Topic StackOverflowException while Layout (Read 1565 times)
roman
Mar 8th, 2011 at 9:01am
Hi Stoyo
I receive a StackOverflow-Exception, during layout of my sample flowchart. Is this Issue http://mindfusion.eu/Forum/YaBB.pl?board=fcnet_disc;action=display;num=125431651... already fixed?
I tested with about 1200 nodes that are linked sequentially and use the Flowchartlayout. I've tested with other layout strategies too, however I only receive the Exception with the Flowchartlayout.
I haven't changed the layout settings, so i use the Flowchartlayout with default settings. Do you know of any solution for this problem?
Thanks in advance
Roman
Re: StackOverflowException while Layout
Reply #1 - Mar 8th, 2011 at 10:25am
Hi Roman,
FlowchartLayout uses most recursive calls from all layout classes and we haven't tried to optimize it yet. The only solution we know of is to increase the process callstack size using the editbin tool. Here's an example setting it to about 2MB:
editbin /stack:2000000 myproj.exe
roman
Reply #2 - Mar 11th, 2011 at 9:33am
Hi Stoyo
Thanks for the reply. I'll try this out.
Roman
