Normal Topic WorkTimeStartHour but half hour? (Read 3069 times)
ahbeng
Mar 9th, 2011 at 6:06am
I'd like to set a different color for my WorkTimeCellStyle. However, I want to make my WorkTimeStartHour start at 8:30 but because it takes an integer only, I can't do it.
Any suggestion on how I can do this?
ahbeng
Re: WorkTimeStartHour but half hour?
Reply #1 - Mar 9th, 2011 at 6:27am
Actually, I was able to get this going by using the method described in this thread.
http://mindfusion.eu/Forum/YaBB.pl?board=calnet_disc;action=display;num=12632053...
john6630
Reply #2 - Mar 14th, 2011 at 10:51pm
What do you do if the cell time is set to 60 minutes so that your start time is in the middle of a cell?
John
Reply #3 - Mar 15th, 2011 at 7:02am
You need to paint the different portions of the cell corresponding to working and non-working time differently. For example, if a cell represents 8:00-9:00 AM and your work time starts at 8:30, you need to paint the upper half of the cell using non-work time settings and the lower half using the work time settings.
Let me know if this helps.
