Normal Topic How to change the TableNode's style? (Read 3036 times)
sweetdeath
Mar 22nd, 2011 at 1:54pm
Hi,Stoyan.The property of "TableStyle" in the Diagram are only two types for us,which are "Rectangle" and "RoundedRectangle".
Can I change the style of the TableNode into other types,such as ellipse or pentagon ?Could you tell me how to change it?
Thanks a lot!
Re: How to change the TableNode's style?
Reply #1 - Mar 23rd, 2011 at 8:08am
You can't assign any other shapes to TableNodes. You could either attach a TableNode to ShapeNode to achieve that (where the table's Brush and Pen are set to transparent color), or create a custom TableNode class that overrides the Draw method to render a shape.
muthuhamid
Reply #2 - Apr 11th, 2011 at 8:37am
Hi Stoyo
How to attach the tree to the table node?.
I saw the class diagram sample in the demo but i could not find the source code for how to attach the tree Node to the table node.
Could you please post me the sample?
Thanks and Regards
Hamid
Reply #3 - Apr 11th, 2011 at 10:05am
Hi Hamid,
The AttachTo method is defined in the base DiagramNode class. You can use it to attach any type of node to any other type of node, e.g.
treeviewNode.AttachTo(tableNode, AttachToNode.TopLeft);
muthuhamid
Reply #4 - Apr 11th, 2011 at 5:37pm
Hi Stoyo
Thanks for your reply...
But i did not achieve my goal. I need to bring the look and feel effect like your "class hierarchy diagram" sample in the Mindfusion Diagram Demo.
Thanks and Regards
Hamid
Reply #5 - Apr 12th, 2011 at 8:54am
Hi Hamid,
This sample shows only TableNodes with the Row.Header property set to true for the "Methods" and "Properties" rows. This allows only for two-levels deep hierarchy. The icons are shown using the Cell.Image property of cells in the first column. The keywords are displayed in blue via the <color> tag while using EnableStyledText mode.
muthuhamid
Reply #6 - Apr 12th, 2011 at 3:48pm
Hi Stoyo
Thanks a lot..that helped lot..
Thanks and Regards
Hamid
