Very Hot Topic (More than 25 Replies) layerlayout (Read 10220 times)
vchimakurthi
layerlayout
Apr 6th, 2011 at 2:46pm
hi,
i was using layer layout.
having just nodes
set to any orientation showing
all nodes in one layer in horizontal
how to display in node in number of  layers
thanks
Re: layerlayout
Reply #1 - Apr 6th, 2011 at 3:14pm
This will treat each node as a separate graph in the diagram and apply the MultipleGraphsPlacement value. Set it to MultipleGraphsPlacement.MinimalArea and the nodes should be arranged as in a grid if they are the same size. If that's the case and you won't ever create links in this diagram, you can also arrange them in a grid as below.
int nodesOnLayer = 10;
for (int i = 0; i < diagram.Nodes.Count; ++i)
	diagram.Nodes[i].Move(
		(i % nodesOnLayer) * 50, (i / nodesOnLayer) * 50);
vchimakurthi
Re: layerlayout
Reply #2 - Apr 6th, 2011 at 3:26pm
thank you
nice and quick reply
vchimakurthi
Re: layerlayout
Reply #3 - Apr 6th, 2011 at 4:22pm
hi how can i chage the shape of node
to particular image
vchimakurthi
Re: layerlayout
Reply #4 - Apr 6th, 2011 at 4:28pm
hi
i have shape nodes  i try to chang shape
if (title == "Report")
              childNode.Image = treeViewImageList2.Images[1];
but inserting image in shape node?
thanks
Re: layerlayout
Reply #5 - Apr 6th, 2011 at 4:30pm
The Image property lets you show a bitmap image inside a node. To change the node's geometric shape, set the Shape property to one of the members of the Shapes class.
vchimakurthi
Re: layerlayout
Reply #6 - Apr 6th, 2011 at 4:49pm
hi
i want to set the shape to particular image shape not the shapes class shapes
can i do that
i even tried using
snode.shape.image=image;
its same this... so how can i
thanks
Re: layerlayout
Reply #7 - Apr 6th, 2011 at 4:55pm
If you need to show only a bitmap image and hide the node's geometric shape, assign the bitmap to ShapeNode.Image and set ShapeNode.Transparent = true.
vchimakurthi
Re: layerlayout
Reply #8 - Apr 7th, 2011 at 8:15am
Hi ,
how can i display text at the bottom of the node instead of the middle
thanks
Re: layerlayout
Reply #9 - Apr 7th, 2011 at 8:28am
// center text at the bottom
StringFormat format = new StringFormat();
format.Alignment = StringAlignment.Center;
format.LineAlignment = StringAlignment.Far;
node.TextFormat = format;
vchimakurthi
Re: layerlayout
Reply #10 - Apr 7th, 2011 at 8:49am
hi stoyo,
but its is still inside the node i want like at the bottom appear like not attached to node.
just below the icon.
thanks
Re: layerlayout
Reply #11 - Apr 7th, 2011 at 9:46am
You could fit both the image and text in the same node if you make the node higher and set ImageAlign = Top and TextFormat.Alignment = Far. Otherwise you could use attached label nodes, or change the TextArea of the shapes you are using, e.g.
Shapes.Rectangle.TextArea = new LineTemplate[]
	new LineTemplate(-25, 100, 125, 100),
	new LineTemplate(125, 100, 125, 150),
	new LineTemplate(125, 150, -25, 150),
	new LineTemplate(-25, 150, -25, 100)
diagram.DefaultShape = Shapes.Rectangle;
If you modify the text region like that, use LineAlignment = Near instead of Far.
Re: layerlayout
Reply #12 - Apr 7th, 2011 at 9:48am
Another option is to use CompositeNodes with a vertical StackPanel inside and add an ImageComponent and TextComponent to the panel.
vchimakurthi
Re: layerlayout
Reply #13 - Apr 7th, 2011 at 11:46am
hi,
then how i can i use attached label nodes.
there is no property or ..
thanks
Re: layerlayout
Reply #14 - Apr 7th, 2011 at 11:55am
