Normal Topic Attach More than one node (Read 2525 times)
muthuhamid
Apr 5th, 2011 at 4:48pm
Hi
How can i attach more than one node to the shape node.?
Thanks and Regards
Hamid
Re: Attach More than one node
Reply #1 - Apr 5th, 2011 at 5:00pm
foreach (DiagramNode node in nodesToAttach)
	node.AttachTo(masterNode...);
muthuhamid
Reply #2 - Apr 6th, 2011 at 9:22am
Thanks a lot ill try now...
Muthu
bravemav
Reply #3 - Apr 8th, 2011 at 6:06pm
Hi, is there a limit on the amount of nodes that can be attached to a shape node?
When I attach more than 50 nodes to a shape node, the attached nodes don't show up in the diagram.
However, attaching 50 or less nodes to a shape node, displays correctly.
Reply #4 - Apr 8th, 2011 at 6:10pm
Hi. There isn't any limit. Could you post the code you are using to place the attached nodes relatively to the main node?
bravemav
Reply #5 - Apr 8th, 2011 at 6:47pm
Ok thanks.
I just needed to know if there was a limit. So now I know the problem is somewhere else.
It's quite a lot of code that takes care of determining which nodes to add to the shape node, so I won't post it, but I'll let you know if I run into any problems.
