Normal Topic How to use the "SaveToStream" method? (Read 2336 times)
sweetdeath
Mar 24th, 2011 at 9:44am
Hi,Stoyan.Suppose I have manually created many TableNodes and Links in the diagram.How can I use the "SaveToStream" method save it into a binary file?
In addition,how can I load the binary file when I open a new diagram? I tried manay times,but I can't work well.The question puzzled me! ???
Could you use the code example to help me make it?
Thanks a lot!
Re: How to use the "SaveToStream" method
Reply #1 - Mar 24th, 2011 at 9:51am
Can't you use the SaveToFile and LoadFromFile methods if you need to save in files?
sweetdeath
Reply #2 - Mar 24th, 2011 at 11:37am
Hi,Stoyan.If I store all the items of the diagram in a "*.fns" file and load it in another diagram. In this case, will the items be changed programmatically via methods and properties in the new diagram?
By the way,how to set the tableNode only move,but can't resize?
Thanks!
Reply #3 - Mar 24th, 2011 at 11:55am
1. You'll still be able to modify the items programmatically if that's what you are asking.
2. Set table.EnabledHandles = Move.
sweetdeath
Reply #4 - Mar 24th, 2011 at 12:01pm
It works as you said!Thanks! Smiley
