Normal Topic Inplace edit (Read 1192 times)
FlyingBird
Inplace edit
Mar 26th, 2011 at 9:14am
I can show a bold string like this "<b>ABC</b>", then "ABC" can be displayed normally. But if I double click it then what i can edit is "<b>ABC</b>", i hope only "ABC".
hoe to do this? thanks.
Re: Inplace edit
Reply #1 - Mar 26th, 2011 at 11:34am
If all text should be bold, change the node's Font instead of using formatting tags. Otherwise you'll have to use a custom editor or replace the textbox' text with the node's PlainText when inplace edit starts in order to hide the tags.
