Normal Topic IconNode not showing in ContainerNode (Read 2692 times)
Dant
Mar 30th, 2011 at 5:16am
Hi.
I create ContainerNode, add in him some IconNode and show diagram.
See ContainerNode but not visible IconNode.
If ContainerNode is selected then IconNode is visible.
how to do that would IconNode was always visible?
Re: IconNode not showing in ContainerNode
Reply #1 - Mar 30th, 2011 at 6:16am
Call IconNode.ZTop() in the end, if it was added before the container.
Dant
Reply #2 - Mar 30th, 2011 at 7:17am
Call IconNode.ZTop() not helpful.
replace IconNode by ShapeNode the same result.
Reply #3 - Mar 30th, 2011 at 7:33am
ZTop() will have effect only if the node has been added to the diagram at that point. I.e. this won't work:
var node = new IconNode();
node.ZTop();
diagram.Nodes.Add(node);
Dant
Reply #4 - Mar 30th, 2011 at 8:59am
I do so
        for()
                ContainerNode cn = diagram.Factory.CreateContainerNode(10, 10, 40, 40);
                cn.Caption = id;
                cn.AutoShrink = true;
                cn.Brush = new MindFusion.Drawing.SolidBrush(Color.FromArgb(32, 0, 0, 0));
                cn.ShadowBrush = null;
                diagram.Nodes.Add(cn);
                for()
                  ShapeNode icn = new ShapeNode(diagram);
                  cn.Add(icn);
            foreach (DiagramNode dn in diagram.Nodes)
                if (dn is ContainerNode)
                    ContainerNode cn = (ContainerNode)dn;
                    foreach (DiagramNode dnn in cn.SubordinateGroup.AttachedNodes)
                        dnn.ZTop();
I do not correctament?
Reply #5 - Mar 30th, 2011 at 9:20am
Do you ever call diagram.Nodes.Add(icn)?
Dant
Reply #6 - Mar 30th, 2011 at 9:34am
ok, after call diagram.Nodes.Add(icn) see shapenodes.
thanks.
