Normal Topic How to draw text? (Read 2293 times)
lenix
How to draw text?
Apr 6th, 2011 at 5:45am
I'm currently evaluating Flowchart.NET and if everything turns out as expected we'll buy it soon.
I got a question though, how can I draw text on the chart? I want separate text ( not shape/node text .. etc).
Would appreciate a quick answer because some development is in progress right now.
Thanks in advance
Re: How to draw text?
Reply #1 - Apr 6th, 2011 at 6:51am
You can use a ShapeNode and set its Transparent property to true to display only the text, and AllowIncomingLinks and AllowOutgoingLinks to false to prevent connecting links to that node. This will let the user select and move the text node; if you want to disable that too, set Locked = true. If you need to draw only a little pre-defined text, you could also do that from the DrawBackground or DrawForeground event handlers.
Reply #2 - Apr 6th, 2011 at 7:01am
I've forgotten our new node type which I should promote - CompositeNode Smiley So you could also create a TextNode type that derives from CompositeNode and adds a single TextComponent to display only text. If you make it an EditComponent instead of TextComponent, the user will be able to directly enter text into the node.
lenix
Reply #3 - Apr 6th, 2011 at 7:37am
I get the first method that you suggested.
But could you show me code example of the second method as I'm not totally sure how to implement it!
Thanks a lot Stoyo
Reply #4 - Apr 6th, 2011 at 7:57am
Here's an example:
public class TextNode : CompositeNode
	public TextNode(Diagram diagram, string label) : base(diagram)
		BorderComponent border = new BorderComponent();
		border.Content = text;
		text.Text = label;
		Components.Add(border);
	public string Label
		get { return text.Text; }
		set { text.Text = value; }
	TextComponent text = new TextComponent();
diagram.Nodes.Add(new TextNode(diagram, "my label"));
You can see a more advanced one in the 'Demo' sample project - EmployeeNode.cs. And there are some tutorials under the "Tutorials / Using Components" section in the help file.
