Normal Topic DiagramLink connection (Read 2802 times)
sledenev
Apr 6th, 2011 at 8:11am
I need programmaticly build diagram nodes and links like this http://img858.imageshack.us/img858/49/20110406115329.png
Links from top node must be perpendicular to bottom nodes. Direction of links is also important.
The only way I see how to do this is to use AnchorPoints, but this solution puts some restrictions to the way user can draw links.
Can you advise another way to do this? Thanks in advance.
Re: DiagramLink connection
Reply #1 - Apr 6th, 2011 at 8:56am
Assuming it's a tree, you could arrange it recursively like this:
float FitChildren(DiagramNode root, float minWidth, float padding)
	float total = 0;
	foreach (DiagramNode child in root.Query("outlinks/destination"))
		total += FitChildren(child, minWidth, padding) + padding;
	total = Math.Max(total - padding, minWidth);
	RectangleF r = root.Bounds;
	r.Width = total;
	root.Bounds = r;
	return total;
void Arrange(DiagramNode root, float levelHeight, float padding)
	float x = root.Bounds.Left;
		child.Move(x, root.Bounds.Top + levelHeight);
		x = child.Bounds.Right + padding;
		Arrange(child, levelHeight, padding);
		StraightenLink(child.IncomingLinks[0]);
void StraightenLink(DiagramLink link)
	RectangleF r = link.Destination.Bounds;
	float x = r.Left + r.Width / 2;
	link.Style = LinkStyle.Polyline;
	link.SegmentCount = 1;
	link.ControlPoints[0] = new PointF(x, link.ControlPoints[0].Y);
	link.ControlPoints[1] = new PointF(x, link.ControlPoints[1].Y);
private void btnTestLayout_Click(object sender, EventArgs e)
	DiagramNode root = diagram.ActiveItem as DiagramNode;
	if (root != null)
		FitChildren(root, 32, 8);
		Arrange(root, 32, 8);
If you need to straighten links drawn by the user, without moving nodes, check the SequenceDiagram example.
sledenev
Reply #2 - Apr 6th, 2011 at 2:41pm
That's exactly what I need. But after nodes arrangement when I move the root node links are back to their original positions. I couldn't find a way to prevent this. I need links to be "fixed" (I've already created group with root node as master item).
Reply #3 - Apr 6th, 2011 at 2:57pm
I forgot to call link.UpdateFromPoints() after the ControlPoints assignments... After you add it, the links should stick to their new end points, as long as they are not Dynamic. This won't make them always stay vertical though, you will have to update all links connected to a node in response to NodeModified or NodeModifying events to achieve that.
sledenev
Reply #4 - Apr 6th, 2011 at 3:01pm
That suits me very well. Thank you very much!
