Very Hot Topic (More than 25 Replies) layerlayout (Read 11569 times)
vchimakurthi
Re: layerlayout
Reply #15 - Apr 7th, 2011 at 12:30pm
hi stoyo
i wrote like
childNode.Shape = Shapes.Terminator;
           childNode.Bounds = new RectangleF(0, 0, 20, 15);
           ShapeNode label =diagram.Factory.CreateShapeNode(0,0,20,15);
           label.AttachTo(childNode, AttachToNode.BottomCenter);
           label.Text = name;
           label.TextFormat.LineAlignment = StringAlignment.Center;
           label.Transparent = true;
           label.Locked = true;
i was not setting the bounds of nodes
arranging using layered layout
but they are arranging leftcentre  of the node
i chang different alignments but the same result
how can i at the bottom
thanks
Re: layerlayout
Reply #16 - Apr 7th, 2011 at 12:48pm
Create the label below the image node, because AttachTo(Bottom) only preserves the initial offset from the attached node to the master node, and won't actually move it there. E.g.
label = diagram.Factory.CreateShapeNode(0,childNode.Bounds.Bottom,20,15);
Then also run LayeredLayout using the KeepGroupLayout option, so that it does not process the labels as independent nodes.
vchimakurthi
Re: layerlayout
Reply #17 - Apr 7th, 2011 at 2:33pm
hi ,
           ShapeNode label = diagram.Factory.CreateShapeNode(0, childNode.Bounds.Bottom, 20, 15);
           label.Text = name;
layerLayout.KeepGroupLayout = true;
but still no change only on left side showing the nodes
thanks
Re: layerlayout
Reply #18 - Apr 7th, 2011 at 2:46pm
It works fine in my test app. Are you sure you have set KeepGroupLayout before calling LayeredLayout.Arrange()?
Re: layerlayout
Reply #19 - Apr 7th, 2011 at 2:59pm
and you are not also running the diagram.Nodes loop from a few posts to arrange nodes in a grid before calling LayeredLayout?
vchimakurthi
Re: layerlayout
Reply #20 - Apr 8th, 2011 at 12:05pm
hi stoyo,
what layout i can use so that no of node connected to center root node  at the middle  and node arranged as in circular manner
thanks
Re: layerlayout
Reply #21 - Apr 8th, 2011 at 12:20pm
TreeLayout with its Type property set to Radial.
vchimakurthi
SpringLayout
Reply #22 - Apr 8th, 2011 at 2:03pm
hi,
i am using spring layout.
how to avoid the overlapping of the link between nodes.
thanks
Re: layerlayout
Reply #23 - Apr 8th, 2011 at 2:29pm
SpringLayout cannot guarantee that, but there should be less overlappings if you set its LinkType property to Rounded. You could also try the v5.6.2 beta, it leaves more empty space around large nodes which should lead to fewer overlappings too.
vchimakurthi
Re: springlayout
Reply #24 - Apr 11th, 2011 at 4:47pm
hi,
how come we prevent nodes overlapping each others in springlayout
(how can i attach an image in the message posting to you)
thanks
Re: layerlayout
Reply #25 - Apr 12th, 2011 at 8:37am
Try setting larger RepulsionFactor, or use v5.6.2 - it should prevent overlapping nodes if the graph is not very dense.
vchimakurthi
Re: layerlayout
Reply #26 - Apr 12th, 2011 at 8:50am
hi,
From where i can download v5.6.2 please give me the link
thanks
Re: layerlayout
Reply #27 - Apr 12th, 2011 at 10:51am
