Normal Topic Link crossing with Origin and Destination (Read 2318 times)
roman
May 9th, 2011 at 7:09am
Hi Stoyo
If the origin and the destination node of a link are wider than the nodes arranged between these start and end nodes, then the link is crossing it's origin and destination node and the nodes between are moved to the side (because of the margin).
The following picture shows the behaviour:
ShapeNode node1 = _flowchart.Factory.CreateShapeNode(0, 0, 50, 10);
node1.TextFormat.FormatFlags |= StringFormatFlags.NoClip | StringFormatFlags.NoWrap;
node1.Text = "Node 1";
node1.Bounds = new RectangleF(node1.Bounds.X, node1.Bounds.Y, node1.Bounds.Width + 20, node1.Bounds.Height);
ShapeNode node2 = _flowchart.Factory.CreateShapeNode(0, 0, 50, 10);
node2.Text = "Node 2";
ShapeNode node3 = _flowchart.Factory.CreateShapeNode(0, 0, 50, 10);
node3.TextFormat.FormatFlags |= StringFormatFlags.NoClip | StringFormatFlags.NoWrap;
node3.Text = "Node 3";
node3.Bounds = new RectangleF(node3.Bounds.X, node3.Bounds.Y, node3.Bounds.Width + 20, node3.Bounds.Height);
DiagramLink link1 = _flowchart.Factory.CreateDiagramLink(node1, node2);
DiagramLink link2 = _flowchart.Factory.CreateDiagramLink(node2, node3);
DiagramLink link3 = _flowchart.Factory.CreateDiagramLink(node1, node3);
this._diagramContainer.Diagram = _flowchart;
FlowchartLayout layout = new FlowchartLayout();
layout.Orientation = MindFusion.Diagramming.Layout.Orientation.Vertical;
layout.LinkPadding = 20;
layout.Arrange(_flowchart);
How can I prevent this behaviour? "Node 2" should be centered and the link between "Node 1" and "Node 3" shouldn't cross the nodes
Thanks in advance
Roman
Re: Link crossing with Origin and Destination
Reply #1 - May 9th, 2011 at 10:49am
Hi Roman,
It seems the algorithm assumes that branches will always occupy more space than the start and end nodes. Our developers will try to fix this for the next release. Now you can work around this only by changing the nodes size before calling Arrange and restoring it afterwards.
Reply #2 - May 11th, 2011 at 7:56pm
Hi Roman,
This version should fix the overlapping problem and ensures that if there is a single non-empty branch, it is centered below the decision node:
https://mindfusion.eu/_beta/fcnet563.zip
roman
Reply #3 - May 12th, 2011 at 6:18am
Hi Stoyo
Thanks for your reply. I'll try this out.
Roman
