Normal Topic Node "jumping" (Read 1908 times)
sledenev
Node "jumping"
May 10th, 2011 at 8:57am
I have ContainerNode (or any other custom node) with minimum size. I am dragging right edge of the node to minimize the node until I reach minimum size.
Size of the node is fixed but cursor is still moving from right to left. When cursor reaches left edge of the node, the node is "jumping" from right to left and starts growing. How can I disable this?
Thanks in advance!
Re: Node "jumping"
Reply #1 - May 10th, 2011 at 1:44pm
It seems we have a NodeConstraints.DisableMirroring constraint in the WPF control for this, we could port it to WinForms in the next couple of weeks. Otherwise you could cancel the resize operation from OnNodeModifying if you detect that the node was flipped.
sledenev
Re: Node "jumping"
Reply #2 - May 10th, 2011 at 2:20pm
It is sad not to have this feature in winforms. I think canceling operation in OnNodeModifying event is bad decision in terms of user's "Look-n-Feel" experience.
It would be nice if you'll port it!
Re: Node "jumping"
Reply #3 - May 12th, 2011 at 12:14pm
Don't be sad 8) This version adds the constraint:
https://mindfusion.eu/_beta/fcnet563.zip
