Hot Topic (More than 10 Replies) two links overlaping (Read 9926 times)
kirri
May 24th, 2011 at 2:19pm
i have 2 nodes and link goes from 1st node to the 2nd . and from 2nd to the 1st. they overlap over each other and i can not see the text that i associated with the links
I tried to add link.route to each link i am creating, but it made no change. as if this property does not affect my diagram.
I just generate the diagram, i do not manipulate with it after.
Please help
Thank you very much
Michal
Re: two links overlaping
Reply #1 - May 24th, 2011 at 2:32pm
The method shown here changes the link shapes to Bezier to pull them apart while keeping common end points:
http://mindfusion.eu/Forum/YaBB.pl?board=fcnet_disc;action=display;num=122711142...
The one here pulls apart straight-line links:
http://mindfusion.eu/Forum/YaBB.pl?board=fcnet_disc;action=display;num=126638813...
kirri
Reply #2 - May 24th, 2011 at 3:06pm
thanks for such  a qucik reply. I hope i will do it
Michal
kirri
Reply #3 - May 25th, 2011 at 10:44am
I am rewriting the code and I can not find out how to deal with input parameter type LinkEventArgs. I can not find it anywhere, so I tried to exchange it for DiagramLink, which has common methods available. But there is a problem with
PointF pt1 = e.Link.ControlPoints[0];
Method DiagramLink.getControlPoint.get(0) does not return the same type as e.Link.ControlPoints[0];
I do not know if I am doing it correctly. Please give me an advice.
Thank you very much
Reply #4 - May 25th, 2011 at 10:49am
That's an event handler for the LinkCreated event, but it won't be raised if you create links programmatically. You could replace it with a void OnLinkCreated(DiagramLink link) method and call it yourself after creating a second link between the same nodes.
The sample code is for our Windows Forms control. In a WPF project your should replace PointF with System.Windows.Point, the link.Style property with link.Shape and the LinkStyle enum with with LinkShape.
kirri
Reply #5 - May 25th, 2011 at 10:53am
I am going to try immediately Smiley. I hope I will do it. Thanks for your reactions, it helps me a lot.
kirri
Reply #6 - May 25th, 2011 at 11:20am
I am writing it in Java, creating a Java application. The only purpose is to generate the image of process graph programatically.
If I call DiagramLink.getControlPoints().get(0), it returns a float. Do I not need it to return a Point?
I can paste a few lines of code where is the problem, if it could help
(I hope you understand, English is not my mother tongue)
Thanks very much
Michal
Reply #7 - May 25th, 2011 at 11:29am
It's not a float number but a Point2D.Float (a Float class embedded in the Point2D interface).
kirri
Reply #8 - May 25th, 2011 at 11:34am
You are right. I did not realized it. I am sorry for that.
Thanks for your advices.
I hope now I will be able to complete it Smiley
Michal
kirri
Reply #9 - May 25th, 2011 at 2:25pm
I rewrote the code according to my needs, but it does not make any changes when I call the method.
I created angle and radius as global variables in order to avoid using reference
Here is how it looks like. If you will have a time, please look at it.
void diagram_LinkCreated(DiagramLink link1)
    List<DiagramLink> commonLinks = new ArrayList<DiagramLink>();
    commonLinks = GetCommonLinks(link1.getOrigin(), link1.getDestination());
    Float pt1 = link1.getControlPoints().get(0);
    Float pt2 = link1.getControlPoints().get(link1.getControlPoints().size() - 1);
    if (commonLinks.size() > 1)
        for (int c = 0; c < commonLinks.size(); ++c)
            DiagramLink link = commonLinks.get(c);
            link.setStyle(LinkStyle.Bezier);
            link.setSegmentCount(1);
            cp1 = new Float(pt1.x + 1 * (pt2.x - pt1.x) / 3, pt1.y + 1 * (pt2.y - pt1.y) / 3);
            cp2 = new Float(pt1.x + 2 * (pt2.x - pt1.x) / 3, pt1.y + 2 * (pt2.y - pt1.y) / 3);
            angle = 0;
            radius = 0;
            CartesianToPolar(pt1, pt2, angle, radius);
            int pairOffset = (c / 2 + 1) * 5;
            if (commonLinks.size() % 2 == 0)
                PolarToCartesian(cp1, c % 2 == 0 ? angle - 90 : angle + 90, pairOffset, cp1);
                PolarToCartesian(cp2, c % 2 == 0 ? angle - 90 : angle + 90, pairOffset, cp2);
                if (link1.getControlPoints().get(0) == pt1)
                    link.getControlPoints().set(1, cp1);
                    link.getControlPoints().set(2, cp2);
                else
                    link.getControlPoints().set(1, cp2);
                    link.getControlPoints().set(2, cp1);
                link.updateFromPoints();
List<DiagramLink> GetCommonLinks(DiagramNode node1, DiagramNode node2)
    for (DiagramLink link : node1.getOutgoingLinks())
        if (link.getDestination() == node2)
            commonLinks.add(link);
    for (DiagramLink link : node1.getIncomingLinks())
    return commonLinks;
void PolarToCartesian(Float coordCenter, float a, float r, Float cartesian)
    if (r == 0)
        cartesian = coordCenter;
        return;
    cartesian.x = (float) (coordCenter.x + Math.cos(a * Math.PI / 180) * r);
    cartesian.y = (float) (coordCenter.y - Math.sin(a * Math.PI / 180) * r);
void CartesianToPolar(Float coordCenter, Float cartesian, float a, float r)
    if (coordCenter == cartesian)
        a = 0;
        r = 0;
        return;
    float dx = cartesian.x - coordCenter.x;
    float dy = cartesian.y - coordCenter.y;
    double x = Math.pow(dx, 2);
    double y = Math.pow(dy, a);
    double sqrt = Math.sqrt(x + y);
    r = (float) sqrt;
    a = (float) (Math.atan(-dy / dx) * 180 / Math.PI);
    if (dx < 0)
        a = a + 180;
    this.radius = r;
    this.angle = a;
Thanks very much
Michal
« Last Edit: May 31st, 2021 at 1:39pm by Forum Admin »
Reply #10 - May 25th, 2011 at 4:43pm
1. Too much copy & paste in your GetCommonLinks Smiley The original checks for Origin in one of the if blocks, your code checks getDestination() twice.
2. .NET has value-equality operator for points, which you should replace with equals(), otherwise it becomes reference comparison.
Here's my Java version (it turned out we have the polar-to-cartesian translation methods in the Utilities class):
	List<DiagramLink> commonLinks = GetCommonLinks(link1.getOrigin(), link1.getDestination());
	Point2D.Float pt1 = link1.getControlPoints().get(0);
	Point2D.Float pt2 = link1.getControlPoints().get(link1.getControlPoints().size() - 1);
			Point2D.Float cp1 = new Point2D.Float(pt1.x + 1 * (pt2.x - pt1.x) / 3, pt1.y + 1 * (pt2.y - pt1.y) / 3);
			Point2D.Float cp2 = new Point2D.Float(pt1.x + 2 * (pt2.x - pt1.x) / 3, pt1.y + 2 * (pt2.y - pt1.y) / 3);
			Point2D.Float radialCoords = new Point2D.Float();
			Utilities.cartesianToPolar(pt1, pt2, radialCoords);
			float angle = radialCoords.x;
				Utilities.polarToCartesian(cp1, c % 2 == 0 ? angle - 90 : angle + 90, pairOffset, cp1);
				Utilities.polarToCartesian(cp2, c % 2 == 0 ? angle - 90 : angle + 90, pairOffset, cp2);
				if (link.getControlPoints().get(0).equals(pt1))
				else
	if (link.getOrigin() == node2)
	return commonLinks;
« Last Edit: May 31st, 2021 at 1:41pm by Slavcho »
kirri
Reply #11 - May 26th, 2011 at 9:38am
Thanks very much, surely it helps. But...I do not know why it does not function for my diagram Cheesy
It makes no changes to it. I must have some mistake in the code I think.
I use very simple methods, I am very new to Jdiagram
At first a create diagram and diagramView. Than I call this method:
private void arrangeDiagram() {
  diagram.clearAll();
  addNodes();
  addEdges(); //adding lines between nodes
  arrange();
arrange() is also very simple, i have used the LayeredLayout sample Smiley
 private void arrange()
  LayeredLayout layout = new LayeredLayout();
  layout.setEnforceLinkFlow(true);
  layout.setStraightenLongLinks(true);
  layout.setNodeDistance(10);
  layout.setLayerDistance(15);
  layout.arrange(diagram);
  diagram.resizeToFitItems(1);
I call the method diagram_LinkCreated(DiagramLink link1) when I create the second link from node1 to node2
Is it wrong? Can you please give me an advice again?
And the second question.. I am also trying to rewrite the code from http://mindfusion.eu/Forum/YaBB.pl?board=fcnet_disc;action=display;num=126638813...
What is the equivalent for node.GetCenter();
Thanks very much for your reply and time
Michal
kirri
Reply #12 - May 26th, 2011 at 11:43am
I DID IT Tongue
I have to collect links that overlap and call the method diagram_LinkCreated for these links AFTER method arrange() Smiley
Maybe it can help somebody too
kirri
Reply #13 - May 31st, 2011 at 11:44am
I have one more question aby link route. When there is a link from node1 to node2 and from node2 back to node1, is it possible to do it as it is shown in the picture attached?
I think I have seen such a topic somewhere, but I am looking for it for a long time and can not find it
https://docs.google.com/leaf?id=0B8vQshcp7q_QYTUzMGIyOGUtZGVmYS00MTNjLWE0ODEtZThkMTA4ZTEzZDU0&hl=en_US
Thank you very much
Michal
Reply #14 - May 31st, 2011 at 12:01pm
Perhaps this one:
http://mindfusion.eu/Forum/YaBB.pl?board=wpfdg_disc;action=display;num=125187153...
That might also work by just setting the end points of the link on the right and calling route().
