Normal Topic Custom positioning of elements (Read 3964 times)
PetrOs
May 26th, 2011 at 12:28pm
I am currently evaluating MindFusion WPF Diagram for our company, and I have a question.
Our application is using MVVM pattern for the User interface. Updates are coming from the model, and a list of elements which should be visible would appear in an observable collection in the view model. I need to create a vew, which would use databinding to this collection, and would convert such collection into diagram nodes on every update (meaning, add new nodes, remove old ones, and position them all). Does anyone have a suggestion, which would be the most optimal way to do this?
Cheers
Petr
Re: Custom positioning of elements
Reply #1 - May 26th, 2011 at 1:32pm
You could use this class in your view, and bind its DataItems property to the collection:
using System.Collections;
using System.Collections.Specialized;
using System.Windows;
using MindFusion.Diagramming.Wpf;
class BoundDiagram : Diagram
	public static DependencyProperty DataItemsProperty = DependencyProperty.Register(
		"DataItems",
		typeof(IList),
		typeof(BoundDiagram),
		new PropertyMetadata(null, OnDataItemsChanged));
	public IList DataItems
		get { return (IList)GetValue(DataItemsProperty); }
		set { SetValue(DataItemsProperty, value); }
	private static void OnDataItemsChanged(DependencyObject d, DependencyPropertyChangedEventArgs e)
		var diagram = (BoundDiagram)d;
		diagram.OnDataItemsChanged(
			(INotifyCollectionChanged)e.OldValue,
			(INotifyCollectionChanged)e.NewValue);
	private void OnDataItemsChanged(
		INotifyCollectionChanged oldItems,
		INotifyCollectionChanged newItems)
		if (oldItems != null)
			oldItems.CollectionChanged -= DataItemsCollectionChanged;
			ClearAll();
		if (newItems != null)
			newItems.CollectionChanged += DataItemsCollectionChanged;
			AddItems(DataItems);
	void DataItemsCollectionChanged(object sender, NotifyCollectionChangedEventArgs e)
		if (e.Action == NotifyCollectionChangedAction.Reset)
			ClearAll();
		else if (e.Action == NotifyCollectionChangedAction.Add)
			AddItems(e.NewItems);
		else if (e.Action == NotifyCollectionChangedAction.Remove)
			RemoveItems(e.OldItems);
	void AddItems(IList items)
		foreach (var item in items)
			var node = Factory.CreateShapeNode(0, 0, 40, 20);
			node.Text = item.ToString();
			node.Tag = item;
		Arrange();
	void RemoveItems(IList items)
			Nodes.Remove(FindNode(item));
		Arrange();
	void Arrange()
		double y = 20;
		foreach (DiagramNode node in Nodes)
			node.Move(20, y);
			y += 35;
		// todo: run some layout algorithm if you also create links
PetrOs
Reply #2 - May 26th, 2011 at 1:52pm
That seems to be exactly what I need! Huge thanks!
