Normal Topic UndoManager (Read 5406 times)
alfrye
UndoManager
Jun 1st, 2011 at 7:13pm
I am using the UndoManager to record actions that can be undone however I am having the following problem,. I have method where I am calling currentDiagram,UndoManager,StartCoposite("test");
and I have some code in between the start and execute and that calls out to another method and that method is removing part the of a diagram link and creating a new diagramlink.
when I try to undo the steps the new diagramlink is remove however the step where I remove part od the line is not being recorded. I have tried creating a new composite command and adding it as a subcommand and that does not seem to work.
Any help would be greatly appreciated.
Alan
AIM
Re: UndoManager
Reply #1 - Jun 2nd, 2011 at 7:08am
If you mean you are changing the link's ControlPoints / SegmentCount properties, you will have to explicitly create a ModifyItemCmd for that and add it to the composite.
alfrye
Re: UndoManager
Reply #2 - Jun 2nd, 2011 at 1:36pm
Thanks Stoyo!!
Do I need to create the ModifyItemCmd command in my main method or the method that is called to clear the controlpopints of the link.
AIM
Re: UndoManager
Reply #3 - Jun 2nd, 2011 at 2:07pm
Hi Alan,
You should create a ModifyItemCmd just before changing ControlPoints, and call its Execute method after that. It should not matter what method creates it, as long as there is a distinct instance for each change.
alfrye
Re: UndoManager
Reply #4 - Jun 2nd, 2011 at 2:22pm
Hi Stoyo,
That is what I thought however the Execute method of the ModifyItem Class in protected virtual . Will changeItem also work or do I have to ModifyItem.
AIM
Re: UndoManager
Reply #5 - Jun 2nd, 2011 at 2:43pm
Sorry, you should actually call Diagram.ExecuteCommand(cmd). That will also add the command to the current composite.
alfrye
Re: UndoManager
Reply #6 - Jun 2nd, 2011 at 2:47pm
Thanks Stoyo!!
I was able to get the my issue resolved by using a ChangeItem command. The reason it was not working before was beacuse I has the create change command in the wrong place. Wink
AIM
Re: UndoManager
Reply #7 - Jun 2nd, 2011 at 2:54pm
Yes, it will do too but might save/restore more stuff than necessary. ModifyItem only saves the item's position, and Change saves all other properties as well. Not a big deal anyway Smiley
