Normal Topic Managing DiagramLink.ControlPoints (Read 1572 times)
Bass
Jun 21st, 2011 at 7:37am
Hi Stoyan,
I was wondering if there is a property for a DiagramLink that could be set programmatically to override the Diagram.AllowSplitLinks.
For most links I do want the behavior that AllowSplitLinks dictates, but for some I dont. I checked the documentation, but I didnt see any event handlers for (adding, removing or..) changing control points of a link in order to "e.Cancel = true;" this operation as an alternative.
For now, I handle the Diagram.LinkModifying event and set e.Cancel to true if needed. But I have seen that at this time a control point can already be added to the collection by dragging the link. Canceling does stop the operation, but the point is already in.
Any ideas?
Bas
Re: Managing DiagramLink.ControlPoints
Reply #1 - Jun 21st, 2011 at 8:22am
Hello Bas,
The only way to do that I can think of is to set AllowSplitLinks dynamically depending on what link is under the mouse pointer. Here's an example that disables AllowSplitLinks for the first link created by the user:
private void diagramView_MouseMove(object sender, MouseEventArgs e)
	PointF mousePosition = diagramView.ClientToDoc(e.Location);
	DiagramLink link = diagram.GetLinkAt(
		mousePosition, Constants.GetLineHitTest(diagram.MeasureUnit));
	if (link != null && link.Selected)
		diagram.AllowSplitLinks = (link != diagram.Links[0]);
		int temp = 0;
		if (diagram.AllowSplitLinks && !link.HitTestHandle(mousePosition, ref temp))
			diagramView.OverrideCursor = Cursors.VSplit;
		else
			diagramView.OverrideCursor = null;
	else
