Normal Topic Difficult to select lines (Read 2246 times)
johkar
Jun 28th, 2011 at 7:22am
If a line is drawn above a shape, it is really hard to select it. You have to place the mouse pointer on excactly the right pixel to be able to do this otherwise the underlying shape will be selected.
Can the selectable area of a line be widened without making the line thicker?
Re: Difficult to select lines
Reply #1 - Jun 28th, 2011 at 8:31am
Try assigning a larger value to the LinkHitDistance property.
johkar
Reply #2 - Jun 28th, 2011 at 8:57am
This property does not seem to affect this. When the line is not above a shape, it will be selected even when the mouse pointer is somewhat distant from the line. The LinkHitDistance property seems to make this possible. But above the shape it is still almost impossible to select the line.
Reply #3 - Jun 28th, 2011 at 9:26am
Have you also set HitTestPriority to ZOrder?
johkar
Reply #4 - Jun 28th, 2011 at 12:17pm
No, that solved the problem! Many thanks.
