Normal Topic DiagramView3D loading issue (Read 2230 times)
Hamdy Ghanem
Jun 28th, 2011 at 2:26pm
After I create nodes and make links between nodes and save
When I load the xml fille the diagram is empty
here is the load code
    diagram.LoadFromXml(mfile.FullName)
  diagramView3D.ResetProjection()
       diagramView3D.Focus()
       diagramView3D.Behavior = Behavior.DoNothing
Re: DiagramView3D loading issue
Reply #1 - Jun 29th, 2011 at 7:52am
3D positions are not serialized with the diagram at this time. As a workaround you could set them as tags and save them by handling the SerializeTag and DeserializeTag events.
Hamdy Ghanem
Reply #2 - Jun 29th, 2011 at 7:55am
Could you provide a sample please
Reply #3 - Jun 29th, 2011 at 9:44am
Assuming you have assigned the point positions directly to the nodes' Tag property:
void diagram_DeserializeTag(object sender, SerializeTagEventArgs e)
	e.Tag = new Point3D(
		e.Context.ReadFloat("X", e.Representation),
		e.Context.ReadFloat("Y", e.Representation),
		e.Context.ReadFloat("Z", e.Representation));
	e.Handled = true;
void diagram_SerializeTag(object sender, SerializeTagEventArgs e)
	Point3D point = (Point3D)e.Tag;
	e.Context.WriteFloat(point.X, "X", e.Representation);
	e.Context.WriteFloat(point.Y, "Y", e.Representation);
	e.Context.WriteFloat(point.Z, "Z", e.Representation);
	e.Handled = true;
Hamdy Ghanem
Reply #4 - Jun 29th, 2011 at 10:08am
Thx
u r always helpful
