Normal Topic Layout problem (Read 2807 times)
Tima
Layout problem
Jul 6th, 2011 at 10:48am
Hi stoyo,
I used JDiagram in swing ,but it seems tough to implement same with java swing.
I used a layout in swing ,
TreeLayout tl = new TreeLayout();
tl.setRoot(null);
tl.setType(TreeLayoutType.Radial);
tl.setLevelDistance(100);
tl.setLinkStyle(TreeLayoutLinkType.Rounded);
tl.arrange(diag);
but unable to use same in java script.
Is there any other way to implement in web applications.....like i see the jspSample example in doc..i need some more example if i use scriplet to use the same code as i used in java swing in web..
Amit
Re: Layout problem
Reply #1 - Jul 6th, 2011 at 10:59am
Hi Amit,
Call DiagramApplet.getScriptHelper().createTreeLayout() to create a TreeLayout instance from JavaScript.
Tima
Re: Layout problem
Reply #2 - Jul 8th, 2011 at 12:06pm
I did this....I asked  it onve in past...
U told me Add MindFusion.Diagramming.TreeLayoutLinkType =
Straight: 0,
Cascading2: 1
Cascading3: 2
Rounded:3
in .js file and call
and call
var diag = applet.getDiagramView().getDiagram();
var tl = applet.getScriptHelper().createTreeLayout();
tl.setTreeLayoutLinkType(3);
// tl.setTreeLayoutLinkType(MindFusion.Diagramming.TreeLayoutLinkType.Round ed);
tl.arrange(diag);
but i m unable to get the layout..
and i need TreeLayoutTye.radial too..
I need exact same layout i m getting from java swing code mentioned above..
Re: Layout problem
Reply #3 - Jul 8th, 2011 at 2:39pm
TreeLayoutType.Radial equals to 2. You can also get such constant values by calling the getConstant method of ScriptHelper, e.g. helper.getConstant("TreeLayoutType", "Radial");
