Normal Topic Regarding FCNETDemo Tools (Read 3467 times)
deepak
Jul 7th, 2011 at 8:43am
I have used the trial version of FCNetDemo for diagramming .NET Winform.
When I have used these tools in my project & rebuild my project that time I got the following error
“Error 1 Exception occurred creating type 'MindFusion.Diagramming.WinForms.DiagramView, MindFusion.Diagramming.WinForms, Version=5.6.3.34220, Culture=neutral, PublicKeyToken=a0d18338041985ba' System.IO.FileNotFoundException: Could not load file or assembly 'MindFusion.Graphs, Version=2.1.1.16834, Culture=neutral, PublicKeyToken=0d09f0b4914ade28' or one of its dependencies. The system cannot find the file specified. E:\MyProject\Properties\licenses.licx 15”
Please give me any solution to handle this error.
Re: Regarding FCNETDemo Tools
Reply #1 - Jul 7th, 2011 at 9:01am
Hi, Are you still using the same trial version?
deepak
Reply #2 - Jul 7th, 2011 at 9:17am
Yes, I m using trial version. Actually currently I testing the tools after that I will buy this software. I m installed this software on 02/07/2011. & I got this error many time.
Reply #3 - Jul 7th, 2011 at 9:29am
Have you ever installed a newer release? You might get such error if you have copied some assemblies from the newer version and MindFusion.Graphs remains from the older version, or the other way around. If all assemblies are from the same release, try adding the following mindfusion* dlls as references with "copy local" set to true: common.dll, diagramming.dll, diagramming.winforms.dll, graphs.dll and svg.dll.
Or did you mean you are getting the error only occasionally?
deepak
Reply #4 - Jul 7th, 2011 at 9:49am
Thanks a lot Smiley
its working...
I add dll in my current project. But when I clean or rebuild my current project ‘svg.dll’ & ‘graph.dll’ are deleted from the bin.
