Normal Topic Copy to image (only selected items) (Read 1375 times)
jpinera
Jul 7th, 2011 at 10:43am
I would like to allow users export to other programs using the clipboard.
I don't find the WmfExport class (where is it?) and I am trying to allow user to export part of the diagram to a bmp image, and store it in the clipboard.
To export the whole diagram is easy:
              Bitmap source = Diagram.CreateImage();
              Clipboard.SetImage(source);
but if I want to copy only the selected items I have problems:
1) I created a Bitmap with the whole diagram
2) I created a RectF that contains all selected items
3) I create an empty bitmap with the same size of the rect created in step 2.
It seem as the coordinates of the bitmap and of the diagram were not the same. The rectF created in (2) is very small.
does exist any method to save to image part of the diagram?
Re: Copy to image (only selected items)
Reply #1 - Jul 7th, 2011 at 11:05am
WmfExporter is in the MindFusion.Diagramming.Export.Wmf.dll assembly.
If you need to export an image only for selected items, you could paste them into an offscreen diagram and export that diagram instead.
Use ClientToDoc and DocToClient to convert between pixels and diagram units.
