Normal Topic Node Tree Expand/Collapse Question (Read 1640 times)
lyrock
Jan 28th, 2013 at 10:22pm
Is there a solution for the following task:
There are multiple child nodes under a root node.
When I click the expand/collapse button, only some child nodes can expand/collapse. The other child nodes are "static nodes".
Thanks.
Yan
Re: Node Tree Expand/Collapse Question
Reply #1 - Jan 29th, 2013 at 7:53am
You could set Visible = true for the static nodes and links from the TreeCollapsed event handler. Alternatively, set ExpandButtonAction to Custom and implement your own expand/collapse from the ExpandButtonClicked handler.
