Normal Topic TreeLayout.Arrange() not updating Diagram.Bounds (Read 1451 times)
Rennie
Jan 29th, 2013 at 11:38am
Not sure if this is a bug or a feature. When additional nodes are added to the diagram, but within the current DiagramView window width, and TreeLayout.Arrange() is then done, the horizontal scroll bar does not come into view even though some of the nodes are now off the right edge of the window. I've taken a look at Diagram.Bounds, and it looks like the width has not been updated either.
This was observed with Balance=Original, and now with Balance=Preserve in 6.0.2 beta.
Re: TreeLayout.Arrange() not updating Diagram.Bounds
Reply #1 - Jan 29th, 2013 at 12:12pm
None of the layout algorithms changes the diagram size. Call ResizeToFitItems after applying a layout, or set it to some union with GetContentBounds result if you need to enforce a minimum size.
Rennie
Reply #2 - Jan 29th, 2013 at 12:38pm
OK, great, thanks.
