Normal Topic hyperlink (Read 3523 times)
vchimakurthi
hyperlink
Jul 11th, 2011 at 12:29pm
hi,
can i display text in shapenode as hyperlink and want to execute  a method on click hyperlink event .
i did set
s.HyperLink="abc"
where s is shapenode
but nothing is displayed as hyperlink.
thanks
Re: hyperlink
Reply #1 - Jul 11th, 2011 at 1:34pm
You will have to set the node's Text, Font and optionally TextColor to make the text look like a hyperlink in a browser.
There's no separate click event for hyperlinks; you will have to run the method in response to the NodeClicked event. However you could call Diagram.MeasureString to find the text size and determine if the click is inside the text's bounding rectangle.
vchimakurthi
Re: hyperlink
Reply #2 - Jul 11th, 2011 at 2:18pm
hi ,
fine i try to add link label to shape node as i c in example
LinkLabel lb = new LinkLabel();
               lb.Click += new EventHandler(lb_Click);
               lb.Text = name;
ControlNode cnode = new ControlNode(diagramView, lb);
cnode.Bounds = childNode.Bounds;
cnode.HandlesStyle = HandlesStyle.MoveOnly;
diagram.Nodes.Add(cnode);
cnode.AttachTo(childNode, AtachToNode.TopCenter);
but link are added in a row at the top of diagram
whats wrong wiht this
thanks
Re: hyperlink
Reply #3 - Jul 11th, 2011 at 2:23pm
If you are running some layout algorithm after adding nodes, set its KeepGroupLayout property to true.
vchimakurthi
Re: hyperlink
Reply #4 - Jul 11th, 2011 at 2:50pm
hi,
can i have minimise and restore button in each shape node
how can i
thanks
Re: hyperlink
Reply #5 - Jul 11th, 2011 at 4:45pm
You will have to implement them using either custom drawing and hit-testing or attached nodes. For the second method check the code from the "Entities" sample project after the "// add buttons to the table" comment.
