Normal Topic Make ShapeNode exactly as big as the text inside (Read 2190 times)
lenix
Jul 12th, 2011 at 7:12am
I'm using transparent ShapeNode's to display labels on my diagrams.
I need the node to be as big as the text with no padding from any of the sides.
I almost got it but I can't seem be able to remove the padding on left of the text.
This is what I do:
float x = 1;
float y = 1;
ShapeNode labelNode = diagram1.Factory.CreateShapeNode(x, y, 155, 6);
labelNode.TextFormat.FormatFlags = StringFormatFlags.NoWrap;
labelNode.Font = new Font("Arial", (float)0.5);
labelNode.Text = "Helllo wrolsdfasdfasdfad";
labelNode.Shape = Shapes.Rectangle;
labelNode.TextPadding = new Thickness((float)-0.071837675, (float)-0.051, (float)-0.100, (float)-0.051);
     // tesrrr.Transparent = true;
labelNode.ResizeToFitText(FitSize.KeepHeight);
labelNode.ResizeToFitText(FitSize.KeepWidth);
labelNode.Move(1, 1);
This is what I get:
Almost as big as the text but there is still padding on the left.
Any ideas?
Thanks in advance!
edit: Also noticed one other thing, the values im setting for TextPadding will not work (padding will be larger if text is longer) when the text inside the node changes.
So I guess I need a new way to do this, any tips are appreciated.
Re: Make ShapeNode exactly as big as the text insi
Reply #1 - Jul 12th, 2011 at 8:11am
The Graphics.DrawString and MeasureString methods leave a couple of pixels on all sides, and they are what ShapeNode uses for measuring and drawing text:
private void Form1_Paint(object sender, PaintEventArgs e)
     string text = "Helllo wrolsdfasdfasdfad";
     Font font = new Font("Arial", 10);
     SizeF size = e.Graphics.MeasureString(text, font);
     e.Graphics.DrawRectangle(Pens.Red, 0, 0, size.Width, size.Height);
     e.Graphics.DrawString(text, font, Brushes.Black, 0, 0);
You could try measuring and custom-drawing texts using the methods of the .NET's TextRenderer instead; it is supposed to be more precise than Graphics.DrawString.
lenix
Reply #2 - Jul 12th, 2011 at 8:29am
Thanks Stoyo,
The problem is that I'm attaching the text to existing nodes, If I don't use a ShapeNode I won't be able to attach it.
Any idea what would be my best bet here?
Thanks again
Reply #3 - Jul 12th, 2011 at 8:56am
You can continue using ShapeNodes, but instead of setting their Transparent property, set CustomDraw=Full. Now the control will raise the DrawNode event for your labels, and you can handle it by drawing them using the TextRenderer.DrawText method. And instead of ResizeToFitText, use TextRenderer.MeasureText to find the text size and resize the node according to it.
