Normal Topic Width read-only (Read 3715 times)
RichardW2C
Width read-only
Jul 20th, 2011 at 10:41am
Hi
When I try to drag and drop a component from the toolbox to the xaml designer, like a SahpeNode, I have an error message saying "The property 'Width' is read-only and cannot be changed".
Re: Width read-only
Reply #1 - Jul 20th, 2011 at 11:04am
How have you managed to add a ShapeNode to the toolbox? It does not derive from Control and should not appear there when you add the diagramming.wpf.dll assembly to the toolbox.
RichardW2C
Re: Width read-only
Reply #2 - Jul 20th, 2011 at 12:16pm
Well, not sure. So I reset the toolbox and dropped the dll. Now I see various layouts in the toolbox, is that ok? What should appear here?
Re: Width read-only
Reply #3 - Jul 20th, 2011 at 1:21pm
Oh, now I see VS2010 shows the nodes indeed, it probably shows all FrameworkElement derived classes, while older versions only showed controls. Nodes don't really have a settable Width, but a Rect Bounds property, and it seems VS decides to assign some value to Width after drag and drop anyway. You could add nodes through Xaml instead:
<diag:Diagram ...>
	<diag:ShapeNode Bounds="40,40,50,50" Shape="Ellipse" />
</diag:Diagram>
RichardW2C
Re: Width read-only
Reply #4 - Jul 20th, 2011 at 1:55pm
When I try that:
<Window x:Class="MaquetteConsole.MainWindow"
	  xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
    xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
    xmlns:diag="http://mindfusion.eu/diagramming/wpf"
    Title="Maquette Console" Width="1200" Height="600"
Loaded="OnWindowLoaded">
    <Grid>
	  <Grid.RowDefinitions>
		<RowDefinition Height="Auto">  </RowDefinition>
		<RowDefinition></RowDefinition>
	  </Grid.RowDefinitions>
	  <Label Name="Etiq" Grid.Row="0">Glop</Label>
	  <ScrollViewer Grid.Row="1">
		    <diag:Diagram Name="diagram"
BackBrush="White"
ShapeBrush="LightBlue"
DefaultShape="Rectangle">
		</diag:Diagram>
		</ScrollViewer>
    </Grid>
</Window>
It compiles and works, but the designer windows show an error message: "The document constains erros that must be fixed before the designer can be loaded".
In the XAML windows, all the diag part inside the ScrollViewer is underlined, and the error tooltip says : "Object reference not set to an instance of an object".
Re: Width read-only
Reply #5 - Jul 20th, 2011 at 7:09pm
Try adding the initial node from the code-behind for the being. We'll check what happens when we add Width and Height setters in the next couple of days.
RichardW2C
Re: Width read-only
Reply #6 - Jul 21st, 2011 at 12:39pm
Ok, thanks.
