Normal Topic Style of LaneGrid (Read 2043 times)
Amosius
Style of LaneGrid
Jul 20th, 2011 at 4:01pm
I have a Gridlane with a Columnheader and a couple of cells as Subheaders. I want to create a Gridlane with dotted lines.
I can set the dashstyle, but my cells on a corner get an smaller dotted line than cell-lines that are adjecent to another cell. This means that opacity or thickness or something makes them stronger / bigger. When I print the diagram everything seems normal. It is only on my diagram and only when i zoom out.
Now i have the following code:
MindFusion.Diagramming.Wpf.Lanes.Style style = new MindFusion.Diagramming.Wpf.Lanes.Style();
                    style.LeftBorderPen.DashStyle = DashStyles.Dot;
                    style.RightBorderPen.DashStyle = DashStyles.Dot;
                    style.BottomBorderPen.DashStyle = DashStyles.Dot;
                    style.TopBorderPen.DashStyle = DashStyles.Dot;
                    for (int column = 0; column < diagram.LaneGrid.ColumnCount; column++)
                        for (int row = 0; row < diagram.LaneGrid.RowCount; row++)
                            pProcess.DiagramProcess.LaneGrid[column, row].Style = style;
So I tried to set thickness of every border of the cell. When I set one thickness = 0, then every border of the cell is invisible:
style.RightBorderPen.Thickness = 0;
So I am a little bit stucked Smiley
Thx for your help.
Amosius
Re: Style of LaneGrid
Reply #1 - Jul 21st, 2011 at 8:54am
All border sides share the same Pen initially. Therefore, in order to hide top and left sides only, assign null values to the appropriate properties in the style instead of modifying their transparency:
style.LeftBorderPen = null;
style.TopBorderPen = null;
Let me know if this helps.
Amosius
Reply #2 - Jul 21st, 2011 at 3:05pm
This helped me, thx very much Smiley
