Normal Topic DiagramLink (Read 1976 times)
Tima
DiagramLink
Jul 25th, 2011 at 8:54am
I need to Create Link between two Nodes but Start from Right Side of Node and End Point of link into the Left Side of another Node.
What should i used for this
Thanks.
Re: DiagramLink
Reply #1 - Jul 25th, 2011 at 10:45am
You can either use appropriate anchor patterns for both nodes or manually adjust the points of the newly created link so that it starts from the right side of the origin node and ends to the left side of the destination node. Here is a sample code illustrating how to do this:
link.ControlPoints.Clear();
link.ControlPoints.Add(new Point(node1.Bounds.Right, node1.Bounds.Top + node1.Bounds.Height / 2));
link.ControlPoints.Add(new Point(node2.Bounds.Left, node2.Bounds.Top + node2.Bounds.Height / 2));
link.UpdateFromPoints();
I hope this helps.
