Normal Topic Drag Drop Shapes (Read 4979 times)
SL_developer
coding rocks
Drag Drop Shapes
Jul 27th, 2011 at 10:02am
How To Drag & Drop shapes from one Diagram to another?
I refered sample drag n drop but its very difficult to understand.
please tell me some another sample in which we can drag n drop shapes.
Re: Drag Drop Shapes
Reply #1 - Jul 27th, 2011 at 10:48am
The Drag & Drop sample is not really that complex. Here is some brief description on how it works:
The Page Structure
The sample contains two diagrams - the left one (named diagram) is the drag & drop source and the right one (named ddtarget) is the drag & drop target. On top of the two diagrams there is an invisible Canvas (named ddplane), which holds a Rectangle (named test). This rectangle is only displayed during dragging and is used to visually represent the dragged node.
The Drag&Drop Logic
1. The left diagram handles the MouseLeftButtonDown event. When this event occurs, the sample checks if the mouse is positioned over the blue rectangle in the top left corner of a node. If this condition is satisfied, the rectangle test is made visible and the sample enters dragging mode.
2. The left diagram also handles the MouseMove event, which is only used during dragging to update the position of the test rectangle in order to give the impression that the node is being dragged.
3. Finally, the left diagram handles the MouseLeftButtonUp event. When this event occurs during dragging and the mouse is positioned over the right diagram ddtarget, a new node is created in this diagram at the mouse position, which is effectively the drop action.
I hope this clarifies things a little.
SL_developer
coding rocks
Reply #2 - Jul 27th, 2011 at 12:38pm
Hi
Thanks for reply here,
now i understand how it works but the thing is that in drag n drop example there is a pre-defined default shape & i want all shapes at left hand side to drag at right side.
Once it drag, same shape should get draw at right diagram.
How can be this possible?
Thanks again
Reply #3 - Jul 27th, 2011 at 12:59pm
Check this sample:
https://mindfusion.eu/_samples/_sample_DragDrop3.zip
It implements dragging of any shape.
SL_developer
coding rocks
Reply #4 - Jul 27th, 2011 at 1:07pm
Hi
this example looks good  Smiley  but why there is only droping of shapes once , if user want the same shape again what he will do?  ??? from where he will get the same shape at right side?
Please tell me what changes i will need in this example to achieve this?
SL_developer
coding rocks
Reply #5 - Jul 27th, 2011 at 1:28pm
hey i found solution,how to do that,
i commented
//if (hits.Contains(test))
// hits.Remove(test);
line of code where you are removing.
Thanks for your kind support. Smiley Smiley Smiley
SL_developer
coding rocks
Reply #6 - Jul 28th, 2011 at 5:29am
In above sample, how can i display only 2 or 3 shapes per line in left side diagram?
Reply #7 - Jul 28th, 2011 at 6:29am
In the MainPage constructor replace:
if (x > 300)...
with:
int shapesPerRow = 3;
if (x > (shapesPerRow - 1) * (size + 5))...
SL_developer
coding rocks
Reply #8 - Jul 28th, 2011 at 6:48am
Thank you  Smiley
