Normal Topic Box Selection Lost (Read 2623 times)
jgedrim
FCX works. I like it.
Box Selection Lost
Jul 31st, 2011 at 8:58pm
I am trying to set some visual feedback based on properties of selected boxes in VB.
It appears that BoxSelectionLost is fired before the selection is lost. How do I detect which box has lost selection in a loop through the selection?
e.g.
Private Sub FCX_BoxSelectionLost(ByVal box As FLOWCHARTLibCtl.IBoxItem)
dim mbox as FLOWCHARTLibCtl.IBoxItem
for each mbox in FCX.SelectedBoxes
    if not (mbox is box) then
    end if
next
This does not work. It does not equate the two boxes mbox and box. Is this because of the byVal parameter?
Basically, I need to iterate the selected boxes AFTER the box has been removed from the selection. Can you help with this please?
Thanks and regards
John
Re: Box Selection Lost
Reply #1 - Aug 1st, 2011 at 9:32am
The following seems to work better:
For i As Integer = 0 To FCX.SelectedBoxes.count
      mbox = FCX.SelectedBoxes.Item(i)
      If Not (mbox Is box) Then
      End If
Next i
Alternatively you can use the SelectionChanged event. It seems to fire after the selection has changed.
