Normal Topic Delete Connected Nodes (Read 1880 times)
SL_developer
coding rocks
Aug 12th, 2011 at 9:25am
How can i delete All connected node?
Suppose One node has 3 connected nodes & if  i delete root node , all nodes should get deleted in diagram.
Re: Delete Connected Nodes
Reply #1 - Aug 12th, 2011 at 9:53am
Presuming that n identifies the node in question, here is the code that removes all nodes connected to n:
foreach (var link in n.GetAllLinks())
      if (link.Origin == n)
            diagram.Nodes.Remove(link.Destination);
      else
            diagram.Nodes.Remove(link.Origin);
