Normal Topic Implementing a custom behavior (Read 4747 times)
petrux
Aug 12th, 2011 at 9:40am
Hi there,
I'm a newbie and this is my first post. ^_^ Here is my question. I'm trying to implement this behavior on a diagram:
1. right click on thi diagram:
1.1 if no node is hit, create a new node
1.2 if a node is hit, user can draw a link to another node having the right mous button pressed, when the right mouse button is released, the link is created. I'd like to have the link preview in this case. But I really can't figure out how to achieve this behavior.
Could you help me (or link any documentation about the issue)?
thanks,
petrux - Italy
Re: Implementing a custom behavior
Reply #1 - Aug 12th, 2011 at 12:24pm
Unfortunately this is not currently possible because the right mouse button cannot be associated with a drawing action. I will see if we can modify the control to support this behavior through customization.
petrux
Reply #2 - Aug 12th, 2011 at 12:27pm
Meppy wrote on Aug 12th, 2011 at 12:24pm:
thanks for your reply.
I'll stay tuned! Smiley
Bye,
petrux
Reply #3 - Aug 15th, 2011 at 7:35am
Get this version of the control:
https://mindfusion.eu/download/WpfDiagram.2.6a.trial.zip
The above version adds a new mouse button action for the right mouse button - Draw. By using the following code, you will enable interactive creation of nodes and links through the right mouse button:
diagram.RightButtonActions = MouseButtonActions.Draw;
Now, in order to create new nodes on click (rather than on click & drag), you need to create a custom behavior class:
public class CustomBehavior : LinkShapesBehavior
      public CustomBehavior(Diagram view)
            : base(view)
      protected override void OnMouseDown(Point mousePosition, MouseButton mouseButton)
            if (mouseButton == MouseButton.Right)
                  var node = Diagram.GetNodeAt(mousePosition);
                  if (node == null)
                        Diagram.Factory.CreateShapeNode(mousePosition.X - 20, mousePosition.Y - 20, 40, 40);
                        Diagram.CancelDrag();
            base.OnMouseDown(mousePosition, mouseButton);
To use this behavior, assign an instance of this class to the Diagram.CustomBehavior:
diagram.CustomBehavior = new CustomBehavior(diagram);
Now, new nodes should be created through right-clicking and links should be created through right-clicking and dragging. Note, that the size of the newly created nodes is hardcoded in the CustomBehavior.OnMouseDown method above.
petrux
Reply #4 - Aug 16th, 2011 at 10:24am
Hi Meppy,
Meppy wrote on Aug 15th, 2011 at 7:35am:
[cut]
thanks for your quick reply. I'll download the trial and try to do something good. By the way - as I assume you're in the development team - is there any address which I can send any suggestion (mostly about documentation)?
Thanks and have a nice day,
petrux
Reply #5 - Aug 16th, 2011 at 10:54am
All suggestions are welcome. Send them along with any additional questions you might have to support@mindfusion.eu.
