I think there is a similar Windows Forms issue for WPF.
When we try to convert WPF Diagram to SVG we encounter this exception:
System.Exception was caught Message=Can't convert the brush of the 'System.Windows.Media.RadialGradientBrush' type Source=MindFusion.Diagramming.Wpf.SvgExport StackTrace: at MindFusion.Diagramming.Wpf.Export.x0e6976d93edd8615.xbb2cbd1695471745(Brush x4c2a99b0c1203b8c, Rect xda73fcb97c77d998, Transform x678241938de24d81) at MindFusion.Diagramming.Wpf.Export.SvgExporter.x593e8c8533662217(DrawingGroup xb5ee4eb70a91d71e, Transform x678241938de24d81, Geometry xf415bfdf81178f19, Geometry x382baa81329e953f) at MindFusion.Diagramming.Wpf.Export.SvgExporter.x1d99ef2e78afcba8(Visual x81deb0c3fdb19a1b, Geometry x382baa81329e953f) at MindFusion.Diagramming.Wpf.Export.SvgExporter.x39b8b9e82da61fbd(Visual x81deb0c3fdb19a1b, Transform xae720f0498ad1d42, Geometry x382baa81329e953f) at MindFusion.Diagramming.Wpf.Export.SvgExporter.x1d99ef2e78afcba8(Visual x81deb0c3fdb19a1b, Geometry x382baa81329e953f) at MindFusion.Diagramming.Wpf.Export.SvgExporter.x39b8b9e82da61fbd(Visual x81deb0c3fdb19a1b, Transform xae720f0498ad1d42, Geometry x382baa81329e953f) at MindFusion.Diagramming.Wpf.Export.SvgExporter.x1d99ef2e78afcba8(Visual x81deb0c3fdb19a1b, Geometry x382baa81329e953f) at MindFusion.Diagramming.Wpf.Export.SvgExporter.x39b8b9e82da61fbd(Visual x81deb0c3fdb19a1b, Transform xae720f0498ad1d42, Geometry x382baa81329e953f) at MindFusion.Diagramming.Wpf.Export.SvgExporter.x1d99ef2e78afcba8(Visual x81deb0c3fdb19a1b, Geometry x382baa81329e953f) at MindFusion.Diagramming.Wpf.Export.SvgExporter.x39b8b9e82da61fbd(Visual x81deb0c3fdb19a1b, Transform xae720f0498ad1d42, Geometry x382baa81329e953f) at MindFusion.Diagramming.Wpf.Export.SvgExporter.x1d99ef2e78afcba8(Visual x81deb0c3fdb19a1b, Geometry x382baa81329e953f) at MindFusion.Diagramming.Wpf.Export.SvgExporter.x39b8b9e82da61fbd(Visual x81deb0c3fdb19a1b, Transform xae720f0498ad1d42, Geometry x382baa81329e953f) at MindFusion.Diagramming.Wpf.Export.SvgExporter.x1d99ef2e78afcba8(Visual x81deb0c3fdb19a1b, Geometry x382baa81329e953f) at MindFusion.Diagramming.Wpf.Export.SvgExporter.x39b8b9e82da61fbd(Visual x81deb0c3fdb19a1b, Transform xae720f0498ad1d42, Geometry x382baa81329e953f) at MindFusion.Diagramming.Wpf.Export.SvgExporter.x1d99ef2e78afcba8(Visual x81deb0c3fdb19a1b, Geometry x382baa81329e953f) at MindFusion.Diagramming.Wpf.Export.SvgExporter.x39b8b9e82da61fbd(Visual x81deb0c3fdb19a1b, Transform xae720f0498ad1d42, Geometry x382baa81329e953f) at MindFusion.Diagramming.Wpf.Export.SvgExporter.x1d99ef2e78afcba8(Visual x81deb0c3fdb19a1b, Geometry x382baa81329e953f) at MindFusion.Diagramming.Wpf.Export.SvgExporter.x39b8b9e82da61fbd(Visual x81deb0c3fdb19a1b, Transform xae720f0498ad1d42, Geometry x382baa81329e953f) at MindFusion.Diagramming.Wpf.Export.SvgExporter.x593e8c8533662217(DrawingGroup xb5ee4eb70a91d71e, Transform x678241938de24d81, Geometry xf415bfdf81178f19, Geometry x382baa81329e953f) at MindFusion.Diagramming.Wpf.Export.SvgExporter.Export(Diagram diagram, String filePath) at S2T.RAHS2.Client.Views.Modeling.DiagramController.Export(ExportFormat format, String filePath) in C:\Users\Ch\Desktop\FOCSVN\ClientViews\Modeling\DiagramController\DiagramControl ler.cs:line 393 at S2T.RAHS2.Client.Views.Modeling.DiagramController.ExportOperation() in C:\Users\Ch\Desktop\FOCSVN\ClientViews\Modeling\DiagramController\DiagramControl ler.Operation.cs:line 136 InnerException:
Thank you.
